你现在位置:首页>技术论文>经验技巧>西门子PLC>正文
西门子S7系列串口通讯模块的信息与使用11.常见问题:在CPU318上连接CP341模板
日期:2008-3-20 19:11:00     来源:   作者:51plcjs 点击:
在CPU318上连接CP341模板,不同协议方式下所能实现的传输速率是多少?
What are the transfer times with CP341 in combination with a 318 CPU?
ANSWER:
The following tables list measured transfer times in relation to transfer protocols. An S7-300 with a CPU318 (6ES7 318-2AJ00-AB0, firmware version V3.0) and a CP341 (firmware version V1.0.2) were used for the time measurements. A function block FB 'P_SND_RK' has been programmed (exclusively) in the user program of the CPU. The time measured is that between the triggering and finishing of a job. The communication partners required for protocols 3964(R) and RK512 were simulated to ensure fastest possible response times.
Baud rate (bit)
76800
57600
38400
19200
9600
4800
2400
1200
600
300
[msec]
[sec]
User data
1 byte
3.7
3.7
3.7
3.7
5
0.01
0.018
0.035
0.069
0.137
10 bytes
5
5.5
6.2
8.9
15.8
0.03
0.059
0.117
0.234
0.468
20 bytes
6.5
7.4
9.3
14.7
27.1
0.053
0.105
0.209
0.418
0.836
50 bytes
11.9
14.2
18.9
33
61.7
0.122
0.243
0.485
0.969
1.939
100 bytes
21.2
25.9
35.4
63.8
120.8
0.237
0.473
0.944
1.888
3.777
200 bytes
39.1
48.2
67.4
124.6
239.3
0.468
0.932
1.863
3.727
7.453
500 bytes
91.6
115.6
163.5
306.8
593.6
1.167
2.314
4.622
9.241
18.483
1000 bytes
181
229
324.8
611.8
1185.8
2.334
4.63
9.221
18.433
36.866
Table 1: Transfer times with ASCII driver (standard with minimum character delay time in each case):
Baud rate (bit)
76800
57600
38400
19200
9600
4800
2400
1200
600
300
[msec]
[sec]
User data
1 byte
5.2
5.6
6.3
10.4
15.1
0.021
0.037
0.071
0.139
0.273
10 bytes
6.7
10.1
10.3
19.7
30.1
0.042
0.08
0.154
0.305
0.607
20 bytes
10.4
10.5
20
20.3
40.2
0.066
0.125
0.246
0.488
0.973
50 bytes
20.1
20.1
29.8
40.2
70.9
0.137
0.265
0.524
1.04
2.076
100 bytes
30
30
40.2
70.2
130.4
0.254
0.497
0.985
1.963
3.917
200 bytes
50.2
59.3
76.6
130.8
250.6
0.486
0.959
1.908
3.802
7.596
500 bytes
100.3
120.5
170.4
320.5
606.4
1.186
2.348
4.674
9.33
18.637
1000 bytes
189.9
235.7
323.5
622
1198.3
2.356
4.664
9.288
18.538
37.035
Table 2: Transfer times with procedure 3964(R) (standard with BCC)
Baud rate (bit)
76800
57600
38400
19200
9600
4800
2400
1200
600
300
[msec]
[sec]
User data
1 byte
11
14.6
20.3
29.6
40
0.07
0.133
0.265
0.525
1.05
10 bytes
12.5
20
20.3
30.3
50.1
0.09
0.17
0.336
0.672
1.344
20 bytes
19.8
20
21.1
40.1
60.2
0.111
0.216
0.428
0.856
1.711
50 bytes
20.4
30.1
30.7
55.4
100.1
0.182
0.354
0.704
1.407
2.812
100 bytes
30.2
39.8
50.3
90.3
160.2
0.3
0.587
1.164
2.328
4.651
200 bytes
60.2
70
90.6
170.5
300.9
0.583
1.147
2.275
4.544
9.085
500 bytes
139.9
170.4
221
381
712.8
1.388
2.731
5.422
10.822
21.625
1000 bytes
280.4
350.9
431.6
752.2
1422.3
2.761
5.43
10.804
21.548
43.029
