你现在位置:首页>技术论文>软件知识>正文
VB CRC校验程序2
日期:2008-3-13 9:18:27 来源:本站整理
1、加入了CRC校验的发送帧
Private Sub Timer1_Timer()                     '定时发送请求
Dim CRC() As Byte
Dim s, str As String
Dim myLo, myHi As String
Dim i As Integer
Dim aa() As Byte
ReDim aa(5) As Byte                           '定义动态数组
      aa(0) = Form1.Text1.Text
      aa(1) = &H3
      aa(2) = &H0
      aa(3) = &HA
      aa(4) = &H0
      aa(5) = &H8
    CRC = CRC16(aa)                          '计算CRC
    str = CRC
    s = ""
      For i = 1 To LenB(str)
            s = s + Hex(AscB(MidB(str, i, 1)))
         Next i
      myLo = Right(s, 2)
      myHi = Mid(s, 1, 2)
      If Len(s) < 4 Then
           myHi = Mid(s, 1, 1)
      End If
    ReDim Preserve aa(0 To 7) As Byte
      aa(6) = Val("&H" & myLo)                   '取CRC校验高低位
      aa(7) = Val("&H" & myHi)
 MSComm1.OutBufferCount = 0                    '清空输出寄存器
 MSComm1.Output = aa                           '发送数据
End Sub
2、CRC校验程序
Function CRC16(data() As Byte) As String
      Dim CRC16Lo As Byte, CRC16Hi As Byte     'CRC寄存器
      Dim CL As Byte, CH As Byte                '多项式码&HA001
      Dim SaveHi As Byte, SaveLo As Byte
      Dim i As Integer
      Dim Flag As Integer
      CRC16Lo = &HFF
      CRC16Hi = &HFF
      CL = &H1
      CH = &HA0
      For i = 0 To UBound(data)
        CRC16Lo = CRC16Lo Xor data(i)           '每一个数据与CRC寄存器进行异或
        For Flag = 0 To 7
          SaveHi = CRC16Hi
          SaveLo = CRC16Lo
          CRC16Hi = CRC16Hi \ 2                '高位右移一位
          CRC16Lo = CRC16Lo \ 2                '低位右移一位
          If ((SaveHi And &H1) = &H1) Then        '如果高位字节最后一位为1
            CRC16Lo = CRC16Lo Or &H80     '则低位字节右移后前面补1
          End If                             '否则自动补0
          If ((SaveLo And &H1) = &H1) Then    '如果LSB为1,则与多项式码进行异或
            CRC16Hi = CRC16Hi Xor CH
            CRC16Lo = CRC16Lo Xor CL
          End If
        Next Flag
      Next i
      Dim ReturnData(1) As Byte
      ReturnData(0) = CRC16Hi                   'CRC高位
      ReturnData(1) = CRC16Lo                   'CRC低位
      CRC16 = ReturnData
    End Function
