你现在位置:首页>技术论文>软件知识>正文
通过VBS编写wincc的看门狗程序
日期:2009-3-29 14:28:40 来源:互联网
wincc由于自身设计的问题,有时会出现假死的状态,这个时候我们一般会采取重新启动机器的方法,但是这样非常麻烦,这里我给大家提供一段vbs脚本,它可以初始化重新启动wincc的服务程序抑制假死。这段程序可以编写成为*.vbs也还可以放在wincc的脚本环境中通过事件来触发,可以起到看门狗的作用。
Do not rearrange sequence of WinCC apps or services
Section for process termination
Set ProcessSet = GetObject("winmgmts:{impersonationLevel=impersonate}").InstancesOf("Win32_Process")
for each process in ProcessSet
 proname = ucase(Left(process.Name,6))
 Select Case proname
 Case "APDIAG"
  process.terminate
 Case "AUTOST"
  process.terminate
 Case "BILDAN"
  process.terminate
 Case "CAREPO"
  process.terminate
 Case "CC_DPS"
  process.terminate
 Case "CC_MSH"
  process.terminate
 Case "CCACTI"
  process.terminate
 Case "CCALGI"
  process.terminate
 Case "CCALGR"
  process.terminate
 Case "CCARCH"
  process.terminate
 Case "CCAUTH"
  process.terminate
 Case "CCCLIE"
  process.terminate
 Case "CCCOMM"
  process.terminate
 Case "CCCONF"
  process.terminate
 Case "CCCSIG"
  process.terminate
 Case "CCDELT"
  process.terminate
 Case "CCDIAG"
  process.terminate
 Case "CCDMCL"
  process.terminate
 Case "CCDMIV"
  process.terminate
 Case "CCLBMR"
  process.terminate
 Case "CCLICE"
  process.terminate
 Case "CCMCPA"
  process.terminate
 Case "CCMETA"
  process.terminate
 Case "CCMIGR"
  process.terminate
 Case "CCNSIN"
  process.terminate
 Case "CCONLC"
  process.terminate
 Case "CCOPCC"
  process.terminate
 Case "CCPACK"
  process.terminate
 Case "CCPERF"
  process.terminate
 Case "CCPJOB"
  process.terminate
 Case "CCPROJ"
  process.terminate
 Case "CCPTMR"
  process.terminate
 Case "CCREDC"
  process.terminate
 Case "CCREDU"
  process.terminate
 Case "CCRTSL"
  process.terminate
 Case "CCRUNR"
  process.terminate
 Case "CCSCRI"
  process.terminate
 Case "CCSSMR"
  process.terminate
 Case "CCSTAR"
  process.terminate
 Case "CCSYNC"
  process.terminate
 Case "CCTEXT"
  process.terminate
 Case "CCTLGA"
  process.terminate
 Case "CCTLGS"
  process.terminate
 Case "CCTMCO"
  process.terminate
 Case "CCTMTI"
  process.terminate
 Case "CCTTRT"
  process.terminate
 Case "CCTXTP"
  process.terminate
 Case "CCUAED"
  process.terminate
 Case "CCUAIU"
  process.terminate
 Case "CCUASE"
  process.terminate
