你现在位置:首页>技术论文>电气常识>仪器仪表>正文
传感器与检测技术常用名词术语中英文对照
日期:2007-11-1 14:03:00 来源:本站整理
点击: 作者:love_651
传感器 :transducer / sensor     ;   转换元件:transduction element ;     敏感元件 : sensing  element ;   电位器式传感器 : potentionmetric transducer / senson   ;  应变式传感器 :strain gauge transducer / sensor ;     电阻:  resistance  ;  电容  :  capacitance  ;  电感式传感器 : inductive  transducer / sensor;电涡流 :   eddy current   ;  光电传感器 :    photoerlectric  transdueer/sansor  ; 光电效应  :photoelectic effect  ;  光伏式传感器 : photovoltaic  transducer/sensor  ;  电导式传感器:  photoconducer transducer / sensor   ;  光纤传感器  :optical  fiber  sensor   ; 热点式传感器: thermoelectric transducer /sensor ;  塞贝克传感器:  seebeck   effect   ; 热敏电阻: thermistor;   正温度系数:(PTC)positive  temperature coefficient;  负温度系数:(NTC)negative  temperature coefficient;  开关温度 : switching temperature ;临界温度 :critical  temperature
压电式传感器 :piezoelectric transducer  / sensor     ;   压阻式传感器 :  piezoresistive   sensor     /  transducer ;   磁阻式传感器:teluetive transducer /sensor ;  差动变压式传感器: differentiai transducer /sensor; 霍尔传感器:  Hall type transducer /sensor  ;霍尔效应:Hall  effect
激光传感器 :laser transducer   气体传感器 :gas transducer ;  电导式气体传感器: conductive gas  transducer  ;金属氧化物气体传感器:metal-oxide gas transducer  /sensor;有机半导体传感器:organic semi-conductor gas transducer / sensor  ;催化式气体传感器:catalytic gas transducer /sensor ;场效应管气体传感器 :FET gas sensor  热导式气体传感器:thermal  conductivity aaa transducer /sensor ;温度传感器:humidity transducer /sensor ;露点元件:dew-point humidity transducer /sensor ;温敏元件:humidity transducer ;辐射传感器:rediation transducer / sensor;  超声波传感器:ultrasonic  transducer /sensoe ;声表面波传感器:surface acoustic wave transducer  /sensor;无源传感器:passive transducer  /sensor;有源传感器:active transducer   /sensor ;数字传感器:digital transducer  /sensor ;模拟传感器: analog transducer   /sensor ;结构型传感器:mechanical  struetare type-transducer /sensor;物型性传感器:physical  property type-transducer /sensor ;复合型传感器:recombination type transducer  /sensor; 集成传感器:integrated sensor 多功能传感器:multi-function transducer   /sensor ;智能传感器:intelligente sensor  ;生物传感器:biosonser
