你现在位置:首页>技术论文>数据通讯>正文
vb.net通过prodave与S7-200通讯
日期:2008-2-15 20:54:58 来源:本站整理
prodave支持与S7-200的通讯,但是在老版本中支持的并不是很好,到了V5.5以上版本时,对200的支持增强了,目前很多组态软件都用这个.看过pradave说明的人都了解通讯函数的声明,但是vb.net中变量类型的改变给我们带来了一定的麻烦,开始以为是prodave不支持,后来仔细读了说明,再仔细研究了一下vb.net的变量说明,才发现原因所在,为方便大家引用这里把声明部分贴出来共享:
 Public Declare Function load_tool Lib "w95_s7.dll" (ByVal nr As Byte, ByVal dev As String, ByRef adr As PLCAdrType) As Integer
    Public Declare Function new_ss Lib "w95_s7.dll" (ByVal nr As Byte) As Integer
    Public Declare Function unload_tool Lib "w95_s7.dll" () As Integer
#Region "S7-200"
    Public Declare Function as200_e_field_read Lib "w95_s7.dll" (ByVal nr As Short, ByVal anz As Short, ByRef value As Byte) As Integer
    Public Declare Function as200_a_field_read Lib "w95_s7.dll" (ByVal nr As Short, ByVal anz As Short, ByRef value As Byte) As Integer
    Public Declare Function as200_a_field_write Lib "w95_s7.dll" (ByVal nr As Short, ByVal anz As Short, ByRef value As Byte) As Integer
    Public Declare Function as200_m_field_read Lib "w95_s7.dll" (ByVal nr As Short, ByVal anz As Short, ByRef value As Byte) As Integer
    Public Declare Function as200_m_field_write Lib "w95_s7.dll" (ByVal nr As Short, ByVal anz As Integer, ByRef value As Byte) As Integer
    Public Declare Function as200_t_field_read Lib "w95_s7.dll" (ByVal nr As Short, ByVal anz As Short, ByRef value As Short) As Integer
    Public Declare Function as200_z_field_read Lib "w95_s7.dll" (ByVal nr As Short, ByVal anz As Short, ByRef value As Short) As Integer
    Public Declare Function as200_z_field_write Lib "w95_s7.dll" (ByVal nr As Short, ByVal anz As Short, ByRef value As Short) As Integer
    Public Declare Function as200_sm_field_read Lib "w95_s7.dll" (ByVal nr As Short, ByVal anz As Short, ByRef value As Byte) As Integer
    Public Declare Function as200_sm_field_write Lib "w95_s7.dll" (ByVal nr As Short, ByVal anz As Short, ByRef value As Byte) As Integer
本新闻共4页,当前在第1页1 2  3  4
