你现在位置:首页>技术论文>数据通讯>正文
如何通过VB以DDE方式与AB PLC进行通讯?
日期:2006-7-10 22:34:27 来源:本站整理
  如何使用Excel通过 DDE VBA方式访问Allen Bradley PLC?
  首先必须先安装RS Linx创建DDE topic. 比如我们定义一个topic名叫“N1”
<<<<<<<<<<<<开始>>>>>>>>>>>>>>>>>>>>>
Public Const DDETOPIC As String = "DDE"
Sub DDEreadStation1()
On Error GoTo MessageRSLinxDead:
    make sure the DDE Channel is Closed before we define a Topic channel
    txtStat1Force.LinkMode = 0
    txtStat1Status.LinkMode = 0
    set the Application and Topic of the Control Property
    DDETOPIC is a Public Constant in MainSubs Module
    I might use a configuration file later and let the user set this
    txtStat1Force.LinkTopic = "RSLinx|" & N1
    txtStat1Status.LinkTopic = "RSLinx|" & N1
    set the Address of the PLC we want to read
    txtStat1Force.LinkItem = "N7:1"
    txtStat1Status.LinkItem = "B3:1/1"
    set the DDE mode to COLD Link, we will request the data manually
    txtStat1Force.LinkMode = 2
    txtStat1Status.LinkMode = 2
    tell VB to get the data from the PLC NOW!
    txtStat1Force.LinkRequest
    txtStat1Status.LinkRequest
    txtStat1TimeStamp.Text = Now()
GoTo SkipMessage
MessageRSLinxDead:
    MsgBox ("RSLINX 没有运行,连接失败!")
SkipMessage:
End Sub
