你现在位置:首页>技术论文>数据通讯>正文
CLX5555 to INVIEW display using Ethernet IP woes
日期:2006-11-27 23:48:00 来源:本站整理
Im having some problems getting a AB Inview display talking to a CLX5555 processor.
Hardware is as follows, Logix 5555, Ethernet ENET/B card, through a switch to the 2706-PENETM module mounted on the inview display.
I have sucessfully setup the ip address for the PNETM with the serial cable and i have changed over to the industrial comms and the signs appearing in RSLINX
I can succesfully upload new messages to the sign, change comms setting in the sign and trigger messages using the inview software.
Ive setup a program to trigger the messages in the processor which is running happily.
BUT im getting no update on the sign when its triggered by the processor.
Has anyone setup one of the ethernet IP ones and got it to work? We have a DH+ one going and that was relativly straight forward.
Ive got a couple of them running - basically followed the example.
I assume youve ocnfigured the IP address of the controller (with path) in the PENET box as well as the IP address for the box itself. Also entered valid trigger tags and message array tags.
The PENET needs to see a 0 to 1 transition in the trigger tag. I think the minimum sample time is 100 msec. so the trigger needs to be in each state for at least 200 msec.
During some recent mods on one of mine, where I had to change the target processor, the unit wouldnt work until I cycled power.
Yes ive set up the data path
10.55.178.41 is my eneb (Control logix 5000)
node path is 1 (backplane) 0 (processor in slot 0)
10.55.178.45 is my inview
subnet 255.0.0.0
I think my problem might be the string im using.
The example that come with my sign said to use this
^T[message number]^M
i think it should be $14[message number] <-- forgotten the end bit
